Replacement side stand
  • Paultrehberg
    • Nov 2015
    • 62
    What is the best replacement side stand for a 46 Chief?
  • PaulCDF
    • Aug 2019
    • 1423
    Jerry Geers
    Parts, restoration and engine work for 1936–1953 Indian motorcycles, from our shop in Deadwood, South Dakota. Search by part number or browse the diagrams for your model and year.
    Starklite
    https://starklite.com/indian-motorcy...ide-stand-leg/
    I have had excellent experience with both.
    • Jim
      • Sep 2001
      • 789
      The '46 Side Stand at Jerry Greers has been out of stock since May of 2021! I asked Starklite for a photo of their '46 side stand but they didn't want to send me a photo.Said it takes too long to do that.
      Jim
      AMCA #6520
      • PaulCDF
        • Aug 2019
        • 1423
        Hmmm;
        "Orginal, part # 87060, 1940 - 1947 Chief, Side Stand, use with 5.00x16"or, 4.00x18" tire, fair condition. "
        Vintage Cycle Bay AKA Jacob Junker
        Good Luck
        • slamiste
          • Mar 2010
          • 260
          Unless you're committed to using the 46-style side stand (to keep your bike year correct) I'd recommend you convert to the 48-style. I believe it is a better, safer design.
          Steve Slaminko
          • PaulCDF
            • Aug 2019
            • 1423
            Jacob Junker has those to;
            NEW, # 821002, 1940 - 1948 Chief, "Jiffy" Side Stand, New mint condition.
            • Paultrehberg
              • Nov 2015
              • 62
              Thank you Steve. That's a better choice.
              • Jim
                • Sep 2001
                • 789
                In my earlier post... I SHOULD have mentioned the ones that Greer is out of stock on is the one for the 16" wheels. The 18" version he has in stock.
                Jim
                AMCA #6520
                • slamiste
                  • Mar 2010
                  • 260
                  Paul,
                  If I remember correctly the 48 style side stand uses a longer front motor mount bolt. If you decide to convert keep that in mind.
                  Steve
                    • 1675
                    Steve, why is the forward mounted '48 stand safer? I'm not debating or doubting your statement, just curious!
                    • slamiste
                      • Mar 2010
                      • 260
                      Since "safer" is a matter of opinion perhaps I should have just said I thought the 48 style was "better". In any case here's what I don't like about the 46 style:
                      1. My experience is that to get the 46 stand down you must lean the bike over center to the right more than I'd like, kick the stand down then lower the bike onto the stand. This is not a pro
                      2. The 46 style is like a pirate's pug leg. It will quickly sink into the ground, or eventually sink into hot/warm asphalt. If you're not paying attention your bike will fall over, hopefully not into someone else's bike. If you kick the bike with leaning on the side stand (which I do not but I see allot of people do) side stand sinking is also a problem.
                      3. Forgetting to put the side stand up before taking off is a potential disaster. I primarily ride Harleys where the side stand is in the forward position so I'm in the habit of looking in that direction for a properly stored side stand.
                      In my experience the 48 style stand alleviates these concerns, maybe not totally, but provides an easy improvement. What I stated is my opinion only and I'm open to counterpoints.
                        • 1675
                        I asked because I recalled that a while ago Gary Stark was on a ride with friends on other vintage Indians, and one of the riders crashed, fatally, due to (maybe, or maybe not) his sidestand being left down. So I was wondering if you had more background on the safety of one style over the other.
                        Gary posted on this forum about the accident, it's confusing because he said the fellow rode a '48, but when the accident happened he was on a '46???...and he couldn't see that his sidestand was down, just as you mentioned Steve. (I've been distracted and left my sidestand down, it scrapes and then it comes up..fast!)
                        https://forum.antiquemotorcycle.org/...-13#post137308
                        • jim wagnon
                          • Dec 2021
                          • 137
                          46’ owner with a ‘48 stand installed. I totally agree with everything Steve shared. It’s an excellent retrofit for sure.
                          Jim
