M344 carbs
  • dommi7
    • Jul 2001
    • 109
    M344 carbs
    I have 2 Chief carbs, can anyone tell me which coke lever and which throttle lever is correct for a 46 Chief?
    TIA
    This gallery has 1 photos.
    Ralph
    TIA
    Dommi7!
    The carb on top has a typical HD civilian sidevalve choke lever (and both throttle levers appear to be HD as well.); The bottom choke lever was the Linkert Indian design.
    PS: Please note how both HS needle knobs are small, "late" ones, yet the LS knob on the bottom carb is a fat earlier one.
    My only clue as to when Indian Linkerts may have switched to the smaller knobs is that HD did by '50, yet much of the fossil record that has crossed my benches suggests that fat knobs were produced on earlier 344s, transitioning to small knobs by'48 at least...
    And we have no evidence that they would have worried if the knobs matched!
    PPS: Please note that neither of the floatvalves have the NPT thread. The brass bowl nut is another enigma, for which I can only offer conjecture.
    • dommi7
      • Jul 2001
      • 109
      Thanks Cotten. Appreciate the info!
      Ralph
        The throttle lever should look like this, Dommi7...
        And you will need to die-chase the floatvalve with a 1/8"NPT die if you have a fuel filter like this...
        PS: That last example was a conservation of a very nice piece, and it also has a fat LS knob with a skinny HS!
