1947 Chief remove handgrips
  • TChief
    • Aug 2018
    • 12
    Alright I am missing something easy how do you remove the handgrips on the Chief? On the Harley there is a screw inside the handgrip but I am missing it on the Indian. I appreciate any help ! Thanks JEFF
    • 968
    unscrew the control sleeve nuts and slide back the sleeve while loosening to remove the sleeve and grip as one.
    • Joseph Mangelos
      • Oct 2019
      • 47
      If you are asking how to actually remove the rubber grips, I use a small screwdriver to slightly lift the grip then my air hose to shoot air between the grip and handlebars.
      • Jim
        • Sep 2001
        • 789
        Check out this video from KIWI. It helped ME figure that same question in a post I had made asking the same type of thing. https://youtu.be/o5iynnkzay0 Watch the whole video, but it does show him screwing it back on around the 15;35 mark
        Jim
        AMCA #6520
