Couple questions for a new '46 Chief owner
    Thanks Lyle, I'll keep that in mind about the LED type.
    Jim
    AMCA #6520
      Here you go.
      https://www.ledlight.com/6-volt-nega...ed-lights.aspx
        I’m going to chime in on question 2. I would look in the rear drive first, as it is really common that the two tabs on the drive washer breaks off and renders the speedo useless.
          Howdy sir,
          Valid point but he does mention it’s clicking at the head unit. The speedo on my much loved 346 dragged out of multi decade storage in 91 with 18k miles was also making ominous noises and only registering mileage not speed. Hesitant to send off this irreplaceable piece, with a few Hail Mary’s took it apart and with a thorough clean lube and one small adjustment it has worked perfectly since. As mentioned, daunting amount of parts but far better quality than the SW on my 348.
          Cheerio,
          Peter
          #6510
          • #20
            Originally posted by Peter Cooke View Post
            Thanks for that Link Peter!!
            I had heard that they do break, but the cable was turning and the "miles" were adding up, but the speedometer MPH needle wasn't moving at all.
            Howdy sir,
            Yes, I was also "leary" of sending it off, but I decided that I would go ahead and send it to Terry Marsh.
            Jim
            AMCA #6520
            • #21
              Yes, I was also "leary" of sending it off, but I decided that I would go ahead and send it to Terry Marsh.[/QUOTE]
              Terry does a great job, and stands behind his work. He rebuilt by speedo and ignition switch.
              • #22
                Thanks for the message of confidence for him. He was recommended to me by a few people. I talked to him and we had a great conversation.
                Jim
                AMCA #6520
