I am getting a '46 Chief running that has sat for a while (I'm not sure how long, but just a few years). This isn't about the different oils, this question is about an oil change and a simple question. The riders book says to drain the crankcase with the bottom screw (B), mine is actually a drain plug. OK, I did that and a lot of oil came out. I did not measure it. The oil in the tank was just about gone but I can't undo the tank drain plug as it is a bit "rounded". I am assuming it drained down into the engine while sitting for a long time. My VLs will do that too.
1. Now... when I add the NEW oil into the tank, is there anything I do to put any oil INTO the engine? OR does it just drain all by itself? My VLs use a pump to put oil into the engine before startup.
2. Do I have to wait after filling the tank before starting?
3. In the Riders Book; What is the screw (A) ABOVE the drain plug for?
Transmission Oil fill bolt question.
1. I loosened the "lock nut" on the top of the transmission, but I could not turn the BIG screw. Is there a "trick" to that? OR is the screw just really tight?
