original chain guard 47 chief
  • cscott
    • Oct 2002
    • 451
    trying to determine if a 47 chain guard had the area where the brake light switch mounts is stamped in or was a separate piece that was spot welded in ? thanks chris
    • 965
    The lower chain guard panel for the brake switch is separate from the main panel.If you look at a plunger chain guard you will see a line the length of the lower potion of the guard above the switch where the separate panel is spot welded.
    • cscott
      • Oct 2002
      • 451
      the one in this picture has a second piece spotted in repop?
        • 965
        After looking at you pic I went back to look again. I think your guard is factory.
        My one very original 47 has a guard like your pic,same as my 51.My other 47 is also came with all its sheet metal, numbers match and in my hands since late seventies and is disassembled .Thats the one I looked at before my first reply.
        It has a stamped one piece lower section.I believe all three are original.
        Maybe they are not all the same from the factory.
        • cscott
          • Oct 2002
          • 451
          here is a picture of the other type, could they both be original ?
          • jim d
            • Sep 2010
            • 281
            I checked mw 51 Chief and the lower section is all one piece stamped out. It was a local bike and original with a earlier repaint over the original paint in the same color. All three previous owners are known with the owner before me having it since around 1980.
            Jim D
            • tomfiii
              • Jun 2007
              • 314
              They started the stamped guard during the '48 model run.
              • cscott
                • Oct 2002
                • 451
                thanks for the info, makes sense now
