rear cylinder misfiring help
  • cscott
    replied
    well I would like to report all fixed but.. replaced the intake seals with peak seals pressurized to 15lbs all good, drained case oil, fired up same thing adjusted carb , no change, have noticed when the exhaust valve stem cover is up on rear there is oil on the stem. thought this was because of misfiring , now starting to think sticking or leaking valves, they were pro re-built so I didn't think so but its looking that way...any thoughts welcome
  • tfburke3
    replied
    Your welcome.
    BTW the Riders Iinstruction book,I have nineth revision for 334, has lots of good info for your bike.Not sure if JG or who sells now,maybe even in the Virtual library.
    In "Sources of motor troubles and remedies"#7 Motor misfires-(a)Poor carburetor adjustment;usually too rich. (b)faulty mag (c)ex valve not seating properly,usually tight(d) spark plugs set wrong or in need of cleaning (e)weak or broken valve springs,replace them
    have fun
  • cscott
    replied
    Thanks Tom, I will give those a try....I have been told many different gaps , good to hear from someone who has the same set-up.chris
  • tfburke3
    replied
    Originally posted by cscott View Post
    thanks Tom, could you also tell me the gap you use on the plugs and mag? thanks chris
    The riders instruction book says .020 for points but dont say which mag.I run.018-.020.
    Spark gap spec is .025-.030.
  • cscott
    replied
  • tfburke3
    replied
    Hi Chris,you need to drain it before for the sitting leak down and after a run to determine the running sump volume .
    Although 1.5 is the factory setting it may be to much and on mine would wet sump,especially on a longer run.TRy 3/4 and if you get oil circulating back dont worry about not enough oil.
    The return pump is not able to keep up with supply so you have the pinch off screw adjustment.
  • cscott
    replied
    hello Tom , if it sits around awhile it will wet sump , I drain it from the upper plug before I run it. What do you think the cause of the wet sumping may be as when running the return line does have oil coming back, I have the supply screw at 1.5 turns , could that be to much? thanks chris
  • tfburke3
    replied
    The position of the points in pic is about where you would be timing front cylinder,with front wire to front plug.
    My mag timed the rear cylinder slightly late even though its also 42,so I had to take a little off the front cam shoe.I doubt the motor would have misfired though.
    Thats a beautiful mag,I wish my rubbing block showed as little wear.
    Also the suggestion about wet sumping is a good point and easy to eliminate by draining the sump after a run and see how much oil is in the sump.
  • TechNoir
    replied
    I am no expert by any means although I have been chasing a fault of my own recently.
    You say it misfires at low revs but is OK at higher revs?
    First fix the intake leak that you mentioned.
    Then get the ignition right. I have always been told that most fueling problems are really ignition problems. Measure the firing point BTDC on both cylinders in case, as Steve mentioned, the mag has the wrong timing.
    Do those two things first before moving on.
    John.
  • Steve Slocombe
    replied
    We must have members more expert than me on magnetos. Over here we had a 50 degree motor fitted with a 45 degree mag which had rear cylinder problems too. A 45 degree mag on a 42 degree motor would also run unevenly. It must be worth one last check before moving elsewhere.
  • cscott
    replied
    hi steve, this is what I have a ffvrs 53 the interrupter is 42 degree and it is set up for counterclockwise rotation heres some pics maybe iam missing some thing100_1967.jpg100_1971.jpg100_1968.jpg100_1969.jpg
  • Steve Slocombe
    replied
    A wrong degree magneto would take a lot of diagnosing...
    replied
    what does anyone think of kiwi composite cones for the intake manifold ? thanks
    Not familiar with them, Chris,..
    Unless they are Endfield Racing's mass-produced PEEK seals.
    Or perhaps Mike is properly custom-cutting PEEK?
    If they stop the bubbles, they work!
  • cscott
    replied
    when at idle or running slow it misses when I ride and speed up it smooths out at higher rpm, the mag is a baby bosch and the gap I tried at 15 and 20 cant get alot of info about this mag, with plugs out and spinning there is good spark at both plugs
  • cscott
    replied
