Originally posted by PRG
View Post
Brass must be set much lower for their mass, but mine are to be set to book spec.
I went to a lot of trouble to calculate their proper volume for proper buoyancy to achieve the same fuel level in the bowl as OEM; Any arbitrary adjustments are at your own risk.
PS: Buzzed Kanker published in his hard-copy rag that my floats should be set higher!
I needed an attorney.
