I got the cylinder manifold nipple out. I punched the pin out Heated the nipple, a little penetrating oil, and it unscrewed with no trouble. I have a new tapered pin. I am thinking of getting some 2000 degree f thread retaining compound, and just using that to hold the nipple in. Or I can drill and ream the hole, then I would need to make a new pin. What about retaining compound, and using a set screw? Any thoughts. Stan
Making progress
Tapered pin, Stan?
Hope you mean a tapered head, because that helps immensely.
Tapered otherwise risks cracking the casting.
Its best to ream and cut a custom rivet to a precise fit from a large nail annealed cherry-red in coals, and cooled slowly.
(OEM button-head rivet shown on top is difficult to seal upon the inside curve of the nipple. Over-size tapered head rivet shown below.)
The problem with two thousand degree goober is you better hope it seals perfectly the first time.
Set screws are ugly.
....CottenAttached FilesLast edited by T. Cotten; 12-20-2019, 08:48 AM.AMCA #776
