Time to check for air leaks
  • stan
    • 205
    After reading a lot of posts on hard starting Chiefs when hot. Appears manifold leaks are a good place to start. I better hook up my manifold air supply adapter, and do a leak check. When I did this a few years ago I got information from someone who advised me to use hi temp copper silicone on the fittings. After this I had no leaks. Things may have changed since I did this. Maybe I can start riding my Chief again. Still would like an electric starter. Stan
    • 8238
    My suspicion, Stan,..
    Is that your assembly would have sealed without the goober.
    I use P4gas to remove silicones quickly.
    • Bubbalowe
      • May 2018
      • 80
      What is P4gas?
        • 8238
        Originally posted by Bubbalowe View Post
        What is P4gas?
        Say it real slow, Bubbalowe!
        Pee for....
        Its that stuff that comes out of the pump they call gasoline.
        Its not as bad as it was.
