I'm just getting my '48 Chief on the road and I am going to put a few miles on it. Given all the distracted boneheads on the road today, I want to add some easily removable aux lights and a horn to make the ride a bit safer. One option is adding a 12v generator and being done with it, but I sort of like keeping things as original as possible, and they work well as is anyway. A second option I'm thinking through is to a license plate mounted LED brake light, some front aux lights made for a motorcycle, and a SoundBomb horn from Denali, and wire them up to a small but powerful 12v aux battery (like these https://antigravitybatteries.com/pro...es/small-case/). I could run nice original looking wires and easily remove it at any time. My math indicates the battery would give me enough juice for several hours of riding and I could then recharge it in between rides. The LED lights only draw an amp or two, though the horn draws a very short peak of 20 amps.
What do you think of the last option? And do people have any better ideas for adding aux lighting to these bikes without upgrading to 12v?
Thanks!
Thanks!
