Help me find thread on starting a Chief
  • Coolbreeze
    Long Rider
    • Aug 2007
    • 320
    I have been riding my '48 Chief for over 50 years, but it can be contrary when it comes to starting at times. I know there is a thread somewhere where our members discuss starting techniques. Please help me find that thread.
    BTW, I am ready to start using ether to get the bike started!
    George Tinkham
    Springfield, IL
    www.virmc.com
    AMCA # 1494
    1941 Indian 841
    1948 Indian Chief
    1956 H-D KHK
    1960 CH
    1964 BMW R69S
    1984 Moto Guzzi V65Sp
  • Skirted
    • Sep 2012
    • 705
    George,
    50 years is a long time! Is it giving you problems particularly when’s it’s cold, hot, warm? Or all of the above?
    Jason Zerbini
    #21594
    • kitabel
      • Sep 2018
      • 471
      Do you have the correct carburetor including venturi and main nozzle?
      Float material?
      Float setting?
      Vacuum leak (throttle shaft)?
      Vacuum leak (manifold, nipples)?
      Spark setting?
      Plug gap?
      The Linkert Book
      • stan
        • 205
        My 47 starts cold with a couple kicks, with the choke on. Then one click down on the choke lever. Then one healthy kick it usually fires up. Hot is a different story. It starts very hard. Seams the more people watching the harder it starts. You may check for air leaks on the manifold. I made up a plate to pressurize the manifold, and use soap to check for leaks. Even with no air leaks my 47 still starts hard hot. Wish I had a better answer for you. Stan
          • 8231
          Stan!
          Did you bubble-test at a full 15psi, using a constant, regulated air supply?
          Sorry I had to ask, but hand pumps, shop vacs, and air mattress pumps give false negatives.
          PS: Holes get bigger when hot.
          • tomfiii
            • Jun 2007
            • 314
            Hot start check coil, it could have a heat soak problem. Also make sure you don't have peaks forming on points as condenser could cause that.
            • Coolbreeze
              Long Rider
              • Aug 2007
              • 320
              Valves seem to be fine. Brand new Bendix carburetor and solid state 12 ignition system from Starklite. For a few weeks, it started fairly well. I let it sit for ~1 1/2 weeks this month; then, it became stubborn. I finally got it to fire up when I used ether on it today. It ran fine once I got it going. Until I figure this out, there will be a container of ether in my saddlebag!
              George Tinkham
              Springfield, IL
              www.virmc.com
              AMCA # 1494
              1941 Indian 841
              1948 Indian Chief
              1956 H-D KHK
              1960 CH
              1964 BMW R69S
              • D.A.Bagin
                • Jan 2008
                • 595
                I've owned my 58 Panhead for almost 50 years. It starts cold usually no issue. After that it could be one kick or a hundred. For 50 yrs. its been a pain in my unowhat. My 57, never an issue.
                • Skirted
                  • Sep 2012
                  • 705
                  Maybe you just need more fuel during priming. Don’t know Bendix carbs but does it have an accelerator pump?
                  Jason Zerbini
                  #21594
                    • 8231
                    Seriously, Folks.
                    HDs and Indians started the same: Both damn easy honest!...
                    When everything's in order.
                    If it don't, then its broken: Fix it.
                    • stan
                      • 205
                      I had a regulator attached to the air supply. Stan
                      • Qtaug
                        • Aug 2019
                        • 12
                        47 Chief
                        Cold start 1st kick- throttle all the way open, choke all the way closed. 2nd. kick throttle all the way closed, choke up one notch. 3rd kick- slightly crack throttle, retard spark 1/2 way and you should be good to go. Hot start- slightly crack throttle, choke all the way open. This works for me!
                        • Coolbreeze
                          Long Rider
                          • Aug 2007
                          • 320
                          Yes, it does.
                          George Tinkham
                          Springfield, IL
                          www.virmc.com
                          AMCA # 1494
                          1941 Indian 841
                          1948 Indian Chief
                          1956 H-D KHK
                          1960 CH
                          1964 BMW R69S
