Wet sumping question/hard to kick
  • Lipdog
    • Aug 2019
    • 151
    I just received my (recently rebuilt) '48 Chief last week and I'm getting familiar with the bike. Yesterday I took it out to the driveway to start it, and kicking it was a bear. I had a friend over (he is 180 Lbs, about 20 more than me) to help and there were times when we could absolutely stand on the kick starter and it wouldn't budge. I finally got it started and it smoked like crazy for 30 seconds or so but then cleared right up. It doesn't seem like this would be the result of a rich condition as that would usually clear up much sooner.
    So I came across the wet sumping issue during my web search. Would this (a) make the bike extremely hard to kick over, and (b) cause the excessive smoking upon start up? I also read about draining oil from the engine in case of wet sumping but I don't understand how to check this and what bolts/plugs to remove. Any detailed help (and even pix if possible) would be *greatly* appreciated.
    Thanks!
    • 959
    Drain the crankcase at the small plug on bottom left case.Fill tank to proper level.If you go to start,check level,if its low and not on the floor its filled the case.
    A slight drop of level is ok but if its a lot you need to drain before starting.If thats the case you need to discuss wet sumping repairs on a 48 pump.
    • ChiefTwoKicks
      • Apr 2008
      • 282
      private message sent... check your box
      • Lipdog
        • Aug 2019
        • 151
        Would wet dumping make the bike harder to kick over?
        I’ll check that tonight. The bike was recently rebuilt, so the pump should be ok. But it sat on a transport truck for 1500 mi so that could have affected it too.
        Thanks!
          • 1664
          Probably! The Rider's Instruction Book shows where the two sump plugs are, the lower plug is for completely draining and the upper plug is for proper level. So if you pull the upper plug and lots of oil flows out then it's definitely wet sumped. The screws are hiding behind the primary and the frame near your clutch pedal, seen from underneath.
            • 959
            If the case has filled with oil ,flyweels dragging in oil ,it will be harder to kick.If its still hard drained then something else is tight.
            BTW wet sumping can also be caused running with low return flow allowing case to fill.This could be worn return pump,clogged sump pick up screen or loose fittings sucking air.
            Once you determine if tis standing or running wet sump you can fix.
            Even new pumps leak down if the ball valve is removed,which I do.This relies on the check valve to hold back the oil.The problem is even with a tight check valve seal the pump body is still flooded and with no seal in the pump drive shaft to 1/4" thick pump cover they still leak.
            The ball valve seals before the pump but you risk it not opening,so I put up with a little leak down.
              • 8229
              Originally posted by tfburke3 View Post
              If the case has filled with oil ,flyweels dragging in oil ,it will be harder to kick....
              They get really hard to kick, Folks...
              When they are so full that there is no space to compress the volume of air beneath the pistons comin' down.
              • PRG
                • Nov 2006
                • 612
                Howdy sir,
                The 48-later aluminum pump is much more prone to wet sumping than its iron counterpart. As the Indian V twin uses the pumping action of piston movement to lubricate all components not directly served by the pump (timing side main and big end) case volume is rather small when measured at BDC compared to TDC. Essentially introducing a quart plus of oil into this small volume is making the engine nearly hydraulic itself when when the rider attempts to turn it over, forcing oil past the rings (smoking which cokes up your piston crowns) and anywhere else it can escape.
                I heartily recommend getting a kiwi ez drain and a dedicated 5 quart oil container and draining off after a ride if this machine is to sit at all. As that size container permits all the oil to be drained off, no measuring required when the next ride comes around, just pour it in and go. Besides the possibility of bending your kicker shaft, routinely starting a wet sumped motor adds to combustion residue as these low compression engines already running dirty do not build enough cylinder temp to burn all of it off. This can lead to hot spots of glowing carbon deposits and detonation, not to mention any breaking loose acting as grinding paste on your bores. Kiwi link below.
                Cheerio,
                Peter
                #6510
                • RichO
                  • Dec 2001
                  • 903
                  Peter, I was surprised you weren't at the Nashville run. Did I understand you sometime back that you might make the Yerba Buena run? Rich
                  DrSprocket
                  • PRG
                    • Nov 2006
                    • 612
                    Howdy Rich,
                    My first cancel in 25 years, 4 surgeries this summer, 3 in 8 days over last couple of wks, last stitches removed Thursday, surgeon will advise wisdom of riding then. We fly out to Carmel on Sunday with our gear and if it looks to be a go the following week am just going to rent a Heritage Softail in Monterrey, not up to wrestling an antique....besides, though I’m two years shy, you can ride a modern piece on Road Runs once you’re 65 so figure I’ll use that favor up now. Thanks for inquiring, pained me mightily to miss that one with my friends, what with it so close to here and all.
                    Cheerio,
                    Peter
                    #6510
                    • Bubbalowe
                      • May 2018
                      • 80
                      I put a small petcock on oil tank at supply line and kick start motor before opening. Before shutting down I close valve and idle a minute to pump oil into tank. Life has gotten a whole lot easier kicking and no sumping.
                      • Lipdog
                        • Aug 2019
                        • 151
                        That's a cool idea as long as you don't forget to turn it on. So I'm clear, you installed it between the tank and the supply line to the engine? Is it a threaded petcock that screws into the tank?
                        • Bubbalowe
                          • May 2018
                          • 80
                          Yes threading into tank, not a new idea. Roller bearing cranks can run a long time without oil, pistons seize first. Probably not the right thing for those with memory loss although I did put a little check oil label on speedo bezel.
                          • PaulCDF
                            • Aug 2019
                            • 1404
                            I am SO glad you asked this question. I have been experiencing something similar: professionally rebuilt engine yet at times a bear to kick over (Just thought it was my old leg). Followed advice of Pisten Bulley above and upper plug yielded ~ a pint. Drained oil tank and will refill before next ride.
                            Valve at tank on feed line sounds like a GOOD idea.
                            I think this is one of the GREAT things about this site. Knowledge, Insights Wisdom to keep these old bikes running than you will not find anywhere else.
                            Thanks again.
                            • RichO
                              • Dec 2001
                              • 903
                              Some of us out here on the left coast have added a shut off valve on different bikes and hooked up a wire so it grounds out the ignition until you turn the valve on just in case the old brain forgets too. just sayin'. See you out here Peter and we don't care what you ride as long as you make the party.
                              DrSprocket
