1946 Chief wiring harness needed!
  • Motorcycle Mike
    • Jan 2019
    • 20
    Gentlemen,
    I am looking for a wiring harness for 1946 Chief with a 1947 sidecar! I would appreciate any help locating a supplier or vendor!🇺🇸
  • Green Indian
    • Apr 2014
    • 303
    Try Jerry Greer: https://www.jerrygreersengineering.c...y=1946&m=Chief
    They have a section for side car parts but I did not see any specific wiring for the tail/brake light. The side car might have a similar wiring like the rear fender on the bike itself.
    Maybe some one else will chime in with thoughts...
    AMCA # 3233
    • Bills37
      • Jan 2010
      • 247
      He sells the cloth wire and loom by the foot along with the terminal ends. You could easily make up the harness for the sidecar.
      • ryan
        • Mar 2017
        • 610
        A good supplier for bulk cloth wire and connectors is http://www.riwire.com
        I know the wiring on harley sidecars, but not indian. Although, I am sure they are simular except maybe for the bike to car plug.
        As for the bike, I am sure any of the dealers can supply that.
        • Motorcycle Mike
          • Jan 2019
          • 20
          Gentlemen,
          Thank you for all your information!
          I actually found a local vendor in Mentor Ohio, Vintage Motorcycle Supply.����
          • ryan
            • Mar 2017
            • 610
            Originally posted by Motorcycle Mike View Post
            Gentlemen,
            Which one is that, CMS? I live in Ohio.
            • tomfiii
              • Jun 2007
              • 314
              Good place to get correct color wire with correct tracer color and they will loom it also.
              • Motorcycle Mike
                • Jan 2019
                • 20
                IMG_20190316_155500.jpg Just returned home with my new American Made wiring harness!
                • ryan
                  • Mar 2017
                  • 610
                  That's great Mike, glad you were able to get it so quickly. Do you even have any wiring in your handlebars? I always like that type of work. I have to finish wiring my 69 FLH with sidecar.
                  • Motorcycle Mike
                    • Jan 2019
                    • 20
                    Thanks, I was amazed that I found it locally and made here! The only wiring in the bars is for high/low beam and the horn. I am removing the sidecar harness and taking it to him for duplication. Good luck on your project! ����
                    • ryan
                      • Mar 2017
                      • 610
                      Is he doing it pro bono to pay for your pattern? Just a thought for both of you to get what you want out of the deal.
                      Good luck with yours and thank you!
                      • tomfiii
                        • Jun 2007
                        • 314
                        Note: Indian's color in wiring diagrams was for tracer color and not color of wire. Also different years used different tracer patterns.
                        • ryan
                          • Mar 2017
                          • 610
                          On wow, that is good to know. Did your new harness have the correct number of tracers on the wires? My 69 harley harness did not.
