info for 1934 chief
  • cscott
    • Oct 2002
    • 451
    info for 1934 chief
    does someone know the correct magneto for a 34 chief and who makes an exhaust system as well, thanks chris
  • tfburke3
    • Oct 2011
    • 964
    Bosh and splitdorf were the optional mags.Mine came,I believe, from the factory with a Bosh FFVRS sometimes called a "baby Bosch"
    I dont know the splitdorf number off hand but it has bakelite cap.no elbow like 38-39 and retained by screws ,not wire like earlier ones.Advance lever on bottom same as 35.
    I used a rigid frame header and exhaust from Greer from the 36 listing which is the same.
    • cscott
      • Oct 2002
      • 451
      Thanks Tom
      • gsottl
        • Apr 2010
        • 216
        The Splitdorf was a type C2. The muffle had the cutout in another position than the later models as far as I know, but the 36 is very well useable on the 34 Chief.
        • tfburke3
          • Oct 2011
          • 964
          A look at some pics of 33 and 35 in Hatfields resto guide shows the 33 cutout at the rear by the fish tip,while 35 shows forward at the beginning of the muffler.
          No 34 exhaust pics in his book so I will have to dig thru some pics.Never noticed that before.Thanks
          • gsottl
            • Apr 2010
            • 216
            That is how it should look like. Picture taken at Kent Thompson“s place a few years back....
            • gsottl
              • Apr 2010
              • 216
              same thing here on an original paint 1932 missing the cut-out...
              • cscott
                • Oct 2002
                • 451
                Thanks for the info, chris
                • 35chief
                  • Dec 2008
                  • 20
                  My 35 Chief is Y and Mag motor and has a Splitdorf CDH Magneto. I replaced my original exhaust with Greers, great fit, heavy and expensive but worth it.
                  • jjcat
                    • Mar 2019
                    • 2
                    Hello is there a chance you could post some photos of how the rear side car frame mounts I have front and center mounts but no rear mounts any info would help
