I have a 1947 Chief and I have an electrical problem that has me stumped. The bike has a volkswagen generator and Bosch regulator. The bike is 6 volts. One day the bike wouldn't start checked the battery and it was showing 4.5 v and wouldn't charge. Replaced battery and bike ran fine for a limited time and then wouldn't start. Checked the new battery and 4.6 v and wouldn't charge battery ruined. Replaced battery and today rode with battery fully charged rode 7 miles bike died. Checked battery .17v and battery ruined. I had checked the generator at idle and showed 7.4v charging. Same at battery. Would when riding the generator be sucking power? Any idea's or suggestions????? THANKS TCHIEF
Electrical problems with Chief
My H-D generator guy explained to me that the new sealed batteries can wreak havoc on generators and regulators/cutouts. I wished I payed more attention to what he said but it had something to do with the generator is overworked and ends up either burned out or it burns out the regulator??? I never use sealed batteries so I didn't give it much thought. May that will give you something to look at. Sorry i don't know more? 46EL
Your generator or regulator has likely failed and needs repair.I have a 1947 Chief and I have an electrical problem that has me stumped. The bike has a volkswagen generator and Bosch regulator. The bike is 6 volts. One day the bike wouldn't start checked the battery and it was showing 4.5 v and wouldn't charge. Replaced battery and bike ran fine for a limited time and then wouldn't start. Checked the new battery and 4.6 v and wouldn't charge battery ruined. Replaced battery and today rode with battery fully charged rode 7 miles bike died. Checked battery .17v and battery ruined. I had checked the generator at idle and showed 7.4v charging. Same at battery. Would when riding the generator be sucking power? Any idea's or suggestions????? THANKS TCHIEF
Get a lead acid battery, check generator output, you need 6.5 volts or more.
If you want to ride your chief with 100% confidence in the 6volt charging system, go here. http://www.splitdorfreg.com/Autolite...n/autolite.htm
You'll need to go back to the original generator (tested, refurbed, etc) with the electronic regulator conversion. Then you can safely run a sealed battery such as the Shorai LFX18 BS06 Lithium Iron 18amp hr which has been designed for and proven to work with this regulator. Many sealed batteries AGM or Lithium Iron have VERY specific charging rates for maximum life. Typically they require a tight charging voltage across all rpms and loads which is rarely ever the case when antique generating/regulating equipment is used.
As has been mentioned, do not run a sealed battery unless you know its limitations on max voltage and then what your charging system is capable of. There are advantages of a sealed battery but often on these old systems, they are not plug and play as many hope. Old charging system - stick with conventional lead acid battery.
There are other options such as going to the Cycle Electric Gen/Reg but I preferred to stick with original appearance hardware that functions better than original. Personal preference.
I am no expert but have seen many charging problems develop due to mismatched components. Generating systems in general are rarely understood and are a primary source of frustration which inhibits ones confidence to ride the bike with any regularity or distance. I converted mine to electronic 5 years ago at the advice of Peter (PRG on this forum) and have ridden many thousands of miles with ZERO maintenance, same battery, and I have NEVER had a battery charger on it even over winter storage.Jason Zerbini
#21594
TChief!
A loose, intermittent ground strap could give such fits.
(One on the battery and one on the generator itself. Beware of insulating powdercoatings, etc.)
Simple things first...
PS: Re-polarizing may be prudent.
PPS: If it were a real Indian Autolite, I'd send it to IndianFrank@yahoo.com
I wouldn't even warn him.Last edited by T. Cotten; 10-19-2018, 04:46 PM.AMCA #776
First, why bother with a 6v Volkswagon generator? Seems like a lateral move at best. The original Autolite's work fine. Personally, I prefer to upgrade to a Cycle Electric 12v with the internal regulator. A major benefit if you're planning to make it a regular rider.
Jeff!Originally posted by TChief View PostTHANK YOU everyone for your insights! I will let you know if I get this figured out! It sure seems to be in general agreement to get a new generator such as the autolite. Will do and get an acid battery. JEFF
An Autolite would be an old generator.
Don't you think you aught to have your Bosch tested before you throw money at it?
PS: Sorry Bill,
But CE endmount regulators are not only ugly, they interfere with Chummee assist springs.
(And lock you in for any future regulator replacements.)Last edited by T. Cotten; 10-21-2018, 01:45 PM.AMCA #776
up grade
I installed a new product from Australia , It's a 12 V alternator but with a body of a 6V generator! Love lt that I can still keep the look! They will accept a dummy regulator! Just's adds to the look.Originally posted by TChief View PostTHANK YOU everyone for your insights! I will let you know if I get this figured out! It sure seems to be in general agreement to get a new generator such as the autolite. Will do and get an acid battery. JEFF
Yea... I'm curious too !! I've been running a 12V Kabota alternator (dynamo) with a companion electronic solid state regulator, mounted inside an Autolite generator case for about 15yrs now. I put it together with the help of the "Virtual Indian" website, refer to an article by Greg Yerex on Autolite conversions. I'm happy with the performance, although the pulley should be smaller so it will spin faster at lower rpms. I have built 3 of these so far. Cost is somewhat less than rebuilding a conventional 3 brush stock Autolite. The faux regulator which appears stock is actually an empty shell, and used to hide the wiring. Looks like a legit, stock unit except for the rotating side, which is covered with the belt guard. I've been using a 12v Oydssey 18amp hr GlassMat type battery (inside a Starklite fiberglas shell). These batteries hold up well as they have a claimed shelf life of more than 6 yrs. Not cheap, at about $130, though. However, I am very curious as the "product from Australia" and what that represents... performance, adaptability (will it spin either direction, Chief or Scout), and cost comparison, etc. To Mr. Fretschel... can you please elaborate on what you found from our Australian friends ? Inquiring minds want to know !! Thanks, Roger Herbison #4284
Continuing with the hijacking of this thread....I've always wondered about Don's Starters and Alternators in Oregon. He will convert an old generator into an alternator while keeping the original case. I've seen his website for a while now, it looks good but I've never come across anyone who has gone the route of his Gener-Nators, take a look:
