Just had a super quick reply to my last question on rings... hope I'm on a roll here
I have come across a few mentions in these forums regarding re-installing the pinion gear to the flywheel pinion shaft.
If hammering the gear back on could loosen the pinion shaft nut off, or even worse put the flywheel assembly out of true, whats the trick ?
Is there a special tool ? can it be easily knocked up ? I certainly would be wary of using the left handed thread and nut to pull the gear back on !
I look forward to reading your solutions.
