46 chief oil return volume
  • Paultrehberg
    • Nov 2015
    • 62
    How much oil should I see coming out of the oil return line inside of the oil tank at idle, and at 35 mph. Stock /orginal oil pump. What I now see is a small amount percolate up and out at idle. At 35mph it has more volume but still percolates.
    • 968
    Sounds right.So long as you see return flow and no wet sumping you should be fine.
    • cdf6333
      • Nov 2008
      • 273
      If your oil tank gets hot after a 10 mile ride, you're fine. Any oil is enough in a roller bearing engine. Pressure or volume mean nothing
