AMCA Mag Winter 93/Spring 94 Tank Repair Article?
Www.yankeechapter.org
Pocketvalve@gmail.com
gas tank solder page 6-1.jpggas tank solder page 7-1.jpggas tank solder page 8-1.jpg
Sorry for the upside down images. For some reason when I try to rotate and save, they came out the same.
I used this process on my 1926 Harley tanks and currently on 1913. Patience is a virtue. Also, although it comes at the very end, when pressure testing do not use 10 psi. Just 2 psi. I actually ballooned my tanks and they would not fit the frame and I have to hammer work them back. Get a fan to blow the fumes away, maybe a mask. There is a lot of tinning and soldering involved. A lot of fumes. I would be happy to provide more input if desired.Dan Margolien
Having attempted a similar repair myself, i too would be interested in this atricle.
A quick google search found a post on the 101 Associations website that states:
"For those aspirants ..........who are brazen enough to attempt their own tank refurbishment ..........there is a comprehensively in depth article, found in the 101 Associations Shop Manual. Found on Page 22A, it was compiled by our esteemed founder and Patriarch, George L. Yarocki. The Late George Yarocki, goes on to describe an in depth process"
I would assume that this is the same materials but it would be interesting iff anyone has this 101 manual and could compare the two.
John
John, it does indeed appear to be the exact same article with the same pictures!Originally posted by TechNoir View PostHaving attempted a similar repair myself, i too would be interested in this atricle
I would assume that this is the same materials but it would be interesting iff anyone has this 101 manual and could compare the two.Pisten Bully is Harry Roberts in Vermont.
Chad, Thank you, and for what its worth, I used free online converter, PDF to JPG to make them small enough to post.Dan Margolien
Originally posted by Zaemo View PostSo...... anyone have any ideas on where to source this terne plate stuff?
It doesn’t appear to be very common.
Z
Its out there for crafting. I looked up tin plated steel.
Also at the local hobby shop, or they can get it. I mentioned K&S in one of my articles for brass tubing and sheet. Th also have small sections of tin plated steel in retail.
K&S Precision Metals serves retail needs for hobby, hardware, or creative motivation. If our stocked products of Brass Tubing, Aluminum Rod, Copper Sheet Metal, or Stainless Steel Strip isn't enough - then send us a message on how we can custom cut your small or large quantity job. RFQs are welcome for your OEM needs!Last edited by DanM; 06-17-2018, 01:23 PM.Dan Margolien
