Mag timing
  • Wayne Mehis
    Old School
    • Jun 2010
    • 22
    Mag timing
    Ok Just to refresh my ol mind The Splitdorf mag gets timed at full advance just like a distributor Thanks
  • gharper
    • Nov 2009
    • 527
    Wayne,
    Yes, set at full advance. Be sure to check the timing on BOTH cylinders!!!!!!! You will find a difference, then you are down to dressing the cam on the points to dial them in so they are the same. Very time consuming process but well worth the trouble!
    Gene
    • Wayne Mehis
      Old School
      • Jun 2010
      • 22
      Thanks for the refresher info Gene
