Magneto
  • 39ChiefBonnie
    • Feb 2014
    • 48
    Magneto
    Hi, I would like to know how to install an Edison Splitdorf Type CDH Magento on my 38 Chief. Does anyone have a step by step guide on the installation and timing procedure. The bike is currently running a battery ignition system with a distributor but I want to put it back to the original specification as it left the factory. Thanks
  • Bills37
    • Jan 2010
    • 247
    Do you have the idler gears installed?
    • Bills37
      • Jan 2010
      • 247
      I had to break it down to make it readable.
      • Bills37
        • Jan 2010
        • 247
        This is out of the Indian repair manual.
        • 39ChiefBonnie
          • Feb 2014
          • 48
          Hi Bills 37,
          Thank you for your post. No I don't have the gears installed yet. I think the bushes may be in the cases but I'm not sure if they need to be replaced. I can't read the attached image on this page. Could I trouble you to email me a copy. Thanks, Matt
          msw@optusnet.com.au
          Cheers
          • Bills37
            • Jan 2010
            • 247
            email sent. I hope it has the info you need. It's from a 48 manual but the engines are all the same.
            • 39ChiefBonnie
              • Feb 2014
              • 48
              Thank you, appreciate your help.
              • someozybloke
                • Oct 2013
                • 68
                Have sent you a PM as well
                Mike
