46 Chief instrument cluster
  • Paultrehberg
    • Nov 2015
    • 62
    What is the purpose of the small hole at the top of the gague cluster. It is above the amp gague and the key switch. About a 5/16 inch size hole.??
  • gsottl
    • 216
    no holes above, but below there are the two holes to mount the dash-cover to the frame..........
    • motor-officer
      • Feb 2011
      • 199
      If there is a single hole generally centered between and slightly above the amp gauge/ignition switch, it was probably added by a previous owner. Many people added an auxiliary light that illuminated the amp gauge that was unlighted and the speedo that, while factory illuminated was not very bright.
