Torque specs
  • John Guntner
    • Feb 2007
    • 192
    Torque specs
    This may help some but it's not complete.
    I don't have time to search the poor "Forum Search Tab" for torque specs so here's what I know and if I've missed some (which I have) please let us know.
    Head Bolts 50-55 Ft Lbs
    Cylinder Base Nuts 35 Ft Lbs
    Drive Sprocket 100 Ft Lbs
    Engine Case Nuts 35 Ft Lbs
  • cdf6333
    • Nov 2008
    • 273
    Hey John
    Where did you get the engine case nuts spec? And probably the cylinder base nuts and the head bolts too?
    35 ft lbs is much too much for the 5/16" Grade 2 bolts use there. I'm pretty sure that it's too high for the cylinder nuts too. I once, and can't quickly find, saw a figure of 45 ft lbs for head bolts. I think Chuck Myles had that info
    Bob
    • John Guntner
      • Feb 2007
      • 192
      Hi Bob
      Engine case nuts may be a steel torque; not for aluminum.
      Cylinder Base nuts is a calculated guess as I'm not able to get a torque wrench in there so I make them tight.
      Head bolt torque comes from Repair and Overhaul Manual, page 7. The Pinion shaft (into the flywheel) nut is on page 14, 100 Ft Lbs.
      I would like to know the torque for the pinion shaft 5/8" nut that holds the oil pump gear, also the left hand threaded Main shaft nut.
      Thanks for your response.
      • John Guntner
        • Feb 2007
        • 192
        Almost 170 views and no fart smeller's, I mean smart feller's out there to share their knowledge. It's still not to late. LOL
        • RonH
          • Jan 2016
          • 213
          You are right John,
          Head bolts 50-55 ft lbs on page 7
          Drive sprocket 100 ft lbs on page39
          I couldn't find anything on the base or case bolts. I am pretty sure you are right on them though!
          • John Guntner
            • Feb 2007
            • 192
            Hi Ron and anyone else interested,
            Here is some good info about nut torque specs:
            For steel:
            1/4" 7~10 ftlbs
            5/16" 15~23 ft lbs
            3/8" 25~40 ft lbs
            7/16" 40~60 ft lbs
            1/2" 50~75 ft lbs
            Threads into aluminum, 2 x diameter of bolt
            All steel, into aluminum, reduce by 30~40%
