1923-26 Big Chief cylinders
  • gharper
    • Nov 2009
    • 528
    I'm in need of a replacement front cylinder for my 24 Big Chief so I can run the 2018 Cannonball, no luck so far........so....
    Just spoke with Stuart Ritchie at JDjugs.com. Once again, I asked about making Big Chief cylinders for 23-26 Big Chief. He is willing to make these cylinders, if he can get 10 sets on order with a deposit. He said they could be produced in about 6 months once enough are on order.
    He would expect the cost to be 3200-3500$ per set and this would include the valve plugs. He mentioned that he would also increase wall thickness slightly and reinforce the underside of the bridge between the valve plug holes.
    If you are interested in a set, please contact Stuart directly at: jdjugs@gmail.com
    Gene Harper
  • bstevens479
    • Jun 2011
    • 109
    Have you tried Kent Thompson in NH 603 585 6933 ?
    • gharper
      • Nov 2009
      • 528
      Indeed I have! Kent is always my first choice but no luck......
