bike has been sitting for a few months and I checked the oil tank and the oil is draining into the crank case. what needs to be replaced to stop this or is the normal?
47 oil pump
Here's some links from previous posts on the subject. I hope they help.
http://www.antiquemotorcycle.org/bbo...light=wet+sump
http://www.antiquemotorcycle.org/bbo...light=wet+sumpAMCA # 3233
It can be quite normal. How much oil is sumping into the crank after how long sitting?Originally posted by john fretschl View Postbike has been sitting for a few months and I checked the oil tank and the oil is draining into the crank case. what needs to be replaced to stop this or is the normal?AMCA # 3233
