1938 Chief Frame
  • Inchief
    • Jan 2014
    • 35
    1938 Chief Frame
    I have what I believe is a 1938 Chief Frame. I have it sandblasted down to bare steel and i cannot see any evidence of a shifter tube below the neck casting. I thought the '38 had this tube for the shifter. The rest of the frame seems to be '38 and the serial number starts with 338 ?
  • D.A.Bagin
    • Jan 2008
    • 595
    338 is for SURE a 38 frame.
    • Inchief
      • Jan 2014
      • 35
      Yes I do think that this is a '38 frame but all I find on a "38 frame says it should have the tube for the shifter linkage on the lower neck casting, this one does not.
      • D.A.Bagin
        • Jan 2008
        • 595
        The number 338 tells all. Many frames and complete motorcycles, after all their years on and off the road, have some modifications to keep them riding down the hi-way.
          • 963
          Unfortunalely the numbers do not always tell the story as they are so easily altered.I have a 38 and the shifter tube is part of the neck casting.
          My guess is I you have a 36 frame,first year for full casting in the neck,no webs,and no shifter tube.
          • Inchief
            • Jan 2014
            • 35
            Yes I was thinking that this is an earlier frame but what is odd is that the neck casting has the dash mount at the top. I believe that dash started in '38.
              • 963
              Good point.38 is first year for flattened tube top to accomodate speedo mounting.
              I looked at my 35 frame and the lower frame tube casting ,no shifter tube ,is rounder than yours with a mold seem,parting line, lateral to tube.
              So my new guess is you have 38 frame that someone ground off the shifter casting.
              Be interesting to see a pic of numbers.
              • Inchief
                • Jan 2014
                • 35
                Upon closer inspection I have come up with the opinion that someone has removed the shifter tube at the bottom of the neck casting. I looked at a '41 frame I have that someone has done a bad job of removing the tube and there seems to be enough material around the frame tubes to leave what I got. Someone has done a nice job of it which made me think it was cast like that but I don't think it came from the factory like that. Thanks for the comments on this.
                • D.A.Bagin
                  • Jan 2008
                  • 595
                  I had no idea we were talking about re-stamped frames. In that case anything could be anything. Guess it could be one of the Polaris frames too.
