1937 Chief Compression Test
  • lrgarrett
    • Apr 2015
    • 6
    When performing a compression test, what should the minimum psi be?
  • sirhrmechanic
    Vigilis
    • Dec 2010
    • 1147
    More important than minimum on a compression test is consistency. If both cylinders are close... that's better than having a super high number.
    Also, do a leakdown test. This tells you a lot more than a compression test. Get a leakdown tester (they aren't expensive). The leakdown test is the most important thing you can do to diagnose an engine's pistons/rings/valves/bore, etc.
    Cheers,
    Sirhr
    • lrgarrett
      • Apr 2015
      • 6
      Thanks for information. Very helpful.
        • 2036
        Its a flathead.If you put your thumb over the spark plug hole and it feels like compression when you kick it over it should start
