Chief After Market Tanks
  • bobmac
    • Mar 2003
    • 22
    Can anyone give me input as to who makes the best replacement tanks for a 1947 Chief? I looked at Kiwi, Greer and Iron Horse Coral and they are all around the same price but it's hard to tell who makes the best one based on a picture. I'd appreciate any guidance in this matter.
    Bob
    #5480
    Bob McDonnell AMCA #5480
    • 1676
    Bob, dunno if this is true, but I heard that Iron Horse supplies the tanks for Greer and Starklite! I note you didn't mention the made-in-India tanks that show up on Ebay.
    • fillibuster
      red dog
      • Aug 2009
      • 934
      Huh! Were those India-made tanks welded or soldered?
      I got some from Starklite and installed them 14 years ago, and have ridden conservatively since, maybe a couple thousand miles a year, amca road runs, chapter functions, a little more. Each tank eventually developed a leak, and had to be sealed, which probably should have been done right away. But they're better than fighting the old soldered stuff.
      More than a few fellas opined that hard-mounting will always take the toll on tanks eventually.
      Still the best $750 I spent on it.
      Best of luck to you.
        • 6034
        On H-Ds, and Indians, I never tighten a gas tank bolt that will put tension on the tank brackets. In other words, tighten one mount, and then shim the rest. On my last Indian, I made rubber washers to cushion the mounts, but I don't know if it made any difference.
          • 1676
          Aluminum! (I think I saw a set on there this weekend...)
          • bobmac
            • Mar 2003
            • 22
            Thanks for the info, I think I'll give the folks at Iron Horse a call.
            • tomfiii
              • Jun 2007
              • 314
              Iron Horse is welded,always fit to frame before doing anything else and use rubber washer between tanks and frame '47-48.
              • bobmac
                • Mar 2003
                • 22
                Will do, thanks.
                • 35chief
                  • Dec 2008
                  • 20
                  I went with Iron Horse 5 or 6 years ago and I was impressed with the tanks. Great fit, little to do to prep for paint as they were very straight and heavy gauge metal. I was going to use them until I could re work my originals but I love the Iron Horse and no issues so my originals look great on my shelf.
                  • motor-officer
                    • Feb 2011
                    • 199
                    I have used a set of Iron Horse tanks on a 1947 Chief since 2003. I paid extra to have them seal the inside. To this day, no problems, no rust and they fit perfectly (knock on wood).
                    • Coolbreeze
                      Long Rider
                      • Aug 2007
                      • 320
                      I agree. That is how I have done it for over 40 years. The soldered tanks on my Chief will punish you if you do not mount them ever so carefully. If it takes an hour or so to mount the tanks without stressing them, it is time well spent. The problems I have had with the tanks occurred after I let someone else mount them.
                      George Tinkham
                      Springfield, IL
                      www.virmc.com
                      AMCA # 1494
                      1941 Indian 841
                      1948 Indian Chief
                      1956 H-D KHK
                      1960 CH
                      1964 BMW R69S
                      1984 Moto Guzzi V65Sp
