M350 Chief Carburator
  • motorpickle
    • Jul 2009
    • 66
    I have a small tech question pertaining to a Linkert M-350. The main carb body has the small bleeder hole in the rearward side of the body by the top bowl rim. This carb came as a "unit" and has the venturi with the air slot in the outward lower side. Is this correct to have a "vented" venturi and a "vented" body? Normal circumstances call for one or the other. Any and all input welcome. I will be ready to fire this project this month and I don't want any hidden time bombs. Thanks in advance....Dz
    • 8248
    Dz!
    Extra venting to the nozzle doesn't seem to hurt a thing.
    (I must plug any extra hole just because I am expected to..)
    Are you certain that it is an opening to the venturi void, and not the little bowl chamber vent on the 'idle' side?
