Gas tank Venting
  • chief46
    • Apr 2014
    • 21
    Gas tank Venting
    I have a 46 Chief and after taking it for a fairly lengthy ride a couple of weeks ago I noticed that gasoline was seeping out of the weep hole above the float bowl. When I removed the gas tank lid I noticed that a significant pressure had built up in the tank. Is this normal? Are the tanks supposed to be vented?
    Thanks Chief46
    • 1675
    Your gas caps should do the venting, something's wrong there...there should be no pressure. Maybe you can put up a picture here of your gas caps?
    • tomfiii
      • Jun 2007
      • 314
      If you have replacement gas caps their pressure spring is too high,you have to dissemble innards to clip spring.Did the gas stop weeping after removing pressure.
      • chief46
        • Apr 2014
        • 21
        I honestly don't know if it stopped weeping or not. I'm going to keep an eye on it. I did check both of my caps. I can suck in on the valve in the bottom of the cap very easily but can't blow out on either of them.
