80" rods
  • fillibuster
    red dog
    • Aug 2009
    • 934
    80" rods
    I've acquired a set of 80" flywheels, but now realize (in the Greer web-site catalog) that the front (forked) rod for an 80 is different than the 74" front rod. The blade rod (rear) is listed as "74 and 80", so I presume the diff has something to do with clearance in the fork area.
    Can somebody clue me in please? .. or refer me to the information?
    • 971
    No difference in dimensions critical to fit.If you look at an eighty female rod the lower end is slightly beefed up.and I think the upper rod ends can also be slightly different with holes for oil instead of slots and no little web,but a more radiused transition from blade to bushing bore.
