Wheel hub bearing race
  • Inchief
    • Jan 2014
    • 35
    Ok I give up. How would one get the bearing race out of the wheel hub for a '38 Chief. I tried a puller then some heat, beat it, cursed at it, it has not budged a bit. Some one told me to run a bead around the race with a stick welder and it will shrink and come out. But I do not have access to a stick welder and I was never any good with one anyway. Any one got any tricks?
    • 1676
    You could try what worked for me on neck bearing races, I cut partially through the race with a Dremel and small wheel, then rapped the cut with a small chisel... that broke the race at the cut point and the race came out. I was careful and managed not to nick the seat for the race!
    • Inchief
      • Jan 2014
      • 35
      Yes I was thinking about trying that. It is pretty tight and is kind of deep. I think I may try to drill through the race with a lesser diameter drill bit than the thickness of the race on a side then try a cutoff wheel and chisel. I am trying this on a hub that is not too good before I try it on the hub that I actually want just to get the technique down so as to not screw up the good one.
