47 oil pump
  • 47 oil pump
    Hello all.I'm new to the forum,been an AMCA member for a year.
    Can anyone tell me the proper o.d. for the late cast iron oil pump plunger and/or the correct clearance in the pump body?And the same for the return gear drive shaft?
    P.S.-I ride a '47 chief
    Plunger Clearance
    Was cruisin' through some messages and saw your question...though you've probably already gotten it answered.
    Clearance should be 0.0005-0.0015 for maximum performance. It doesn't really matter what the correct bore size is if you've got clearance correct. A good fix is to hard-chrome the plunger and grind it to spec.
      Brian-Thanks for the reply.I did get an answer earlier ,but it isn't the same as yours.Rocky Halter miced up some NOS pumps for me an found a lot looser fit.
      Do you mind telling me where your info is from?I get paranoid about things like this!
      Thanks Tom P.
        I did it to a friend's oil pump and it worked fantastic. Guessed on the clearance. Figure it's gotta be small enough to stop any wet sumping from occuring while the bike is parked.
          Thanks Brian-I went back and checked my notes and Rocky's dimensions aren't that much diferent from yours after all-in fact there is some overlap.
          Thanks again for the reply
