Rigid Frame Transmission
  • Inchief
    • Jan 2014
    • 35
    Hi, I am a new member and this is my first post. I have a '38 chief frame and I am putting a '48 motor in it. As I understand it I need to change the transmission main shaft and the driver gear. I believe the parts are longer for a rigid frame chief. I have some parts that are useable but I am unsure if they are for a rigid or sprung frame. Does anyone have the parts for a rigid frame Chief that they can measure the length of and let me know so I can see if what I got will work. Thanks
    • 968
    The drive shaft and driver gear are shorter for a rigid frame. I can measure after the weekend if needed.You also need a ridged inner primary cover with straight rather than angled chain adjuster.
    And you will need to fabricate a belt cover when you put generator behind seat post,or else let belt run uncovered.
    • Inchief
      • Jan 2014
      • 35
      I measured what I got the drive shafts are 10 7/8" long, all the same lengths. I suspect for later Chief.
      The Driver gears are 2 1/4", 2 5/8" and I got one at 2 7/8" long but it is missing a tooth. I suspect the 2 1/4" for rigid frame and 2 5/8" for late Chief. And yes I have a early primary for rigid frame, I was hoping that a later model belt guard will work.
        • 968
        Check out Jerrygreerindian web site.He has diagrams with dimensions that help identify the various different year Indian parts 36-53.
        • Inchief
          • Jan 2014
          • 35
          Yes Greers had good parts drawings. Helped a lot, thanks.
