1947 Chief front wheel install
  • agreeneone
    • Nov 2013
    • 42
    I'm hopeing someone could someone tell me the correct procedure, possibly step by step for installing the front wheel on my 47 chief. I know this may seem simple to some but this is my first attempt at doing this and I am having a difficult time. I had the wheel off to replace the brakes and front bearing. I now have it back together and the brake assembly mounted to the wheel to install it. The hollow axle is in place extending thru the backing plate. The problem I am having is I cannot get the hollow axle back to into position in the fork without having to force it. I was using the solid axle to tap the hollow axle into the fork and this is causing damage to the bearing and retaining nut.
    Any suggestions would be greatly appreciated.
  • cdf6333
    • Nov 2008
    • 273
    Yo. Attach the backing plate and drum to the fork. Then let all the air out of the tire and squeeze it in. Tight but goes.
    • Skirted
      • Sep 2012
      • 709
      When following above instructions, if you are still having problems getting the sleeve/bearing race started into the fork, you can spread the fork opening up (carefully) by inserting an appropriate size screw driver in the pinch slot as a wedge. Shouldn't take much. Everything should go together without beating using some patience and finesse
      Jason Zerbini
      #21594
      • agreeneone
        • Nov 2013
        • 42
        Thanks for the advice! It is very much appreciated.
