1947 Chief unique cam cover and oil pump
  • cdf6333
    • Nov 2008
    • 273
    I had a 1947 mag Chief engine that was stolen back in Jersey during the 80's. It was apart and was strange in that it had the cam cover that I've enclosed a picture of. There was no vent on the cover. It also had a strange oil pump. The pump was like the square late 46 and 47 pump except that it had:
    a. a 3/8" pipe threads (instead of the usual 1/4" pipe threads) in the upper left corner. It used a vent/chain oiler like a Sport Scout
    b. inside the pump body was a machined "plug", with a rubber gasket on each side, to control crankcase pressure, similar to the breather disc.
    Are any of these on the road today? I believe the engine number was CDG 6999 but memory and all is iffy. I had these parts down at the shop and still have them. Seem low miles, original gasket was on the cam cover.
    • 1676
    Bob, possible that your cam cover and oil pump were set up for a stationary application, or did they come matched up to a frame? I've never seen one like that (but of course there's lots I've yet to see!)
    • OldMCRider
      • Apr 2008
      • 12
      cdf, I have a cover like this, without the vent. I think it was from a 38 Chief.
      • cdf6333
        • Nov 2008
        • 273
        I'm pretty sure that the 1938 cover had the "fingers" that wrapped around the tappet guides, didn't it? I think that all Chief before mid 46 had the bigger cover. Any help here?
