Indian battery vent tube
  • Fredthecat
    • May 2013
    • 25
    I have new Greer reproduction Indian battery shell with modern 6 volt lead acid 6N11 Jap battery inside.
    How do you route battery vent tube out of the shell?
  • tomfiii
    • Jun 2007
    • 314
    If you have room a little plastic squeeze bottle along side of battery in case or you will have ti drill hole in inconspicuous place to rout it.
    • Fredthecat
      • May 2013
      • 25
      Thanks for the ideas. Yep, a hard plastic rectangular box, think Dental Floss or 3x5 index card case, will fit perfect inside shell and help stop front-rear battery movement also. Hole in top for tube in, a few small holes in top for air, strip of battery mat acid neutralizer in bottom.
      Thanks!
