47 Chief Magneto Mounting?
  • 49panhead
    • Nov 2012
    • 11
    I have a 1947 Chief that I want to mount an Edison-Splitdorf RM magneto on.
    I'm looking for any advise that may be helpful!
    Also what is used to seal the magneto to the case?
  • gsottl
    • 216
    The bushing has oilgroves that should keep the oil from getting out at the magneto gear if the play of the pear in the bushing is right.
    I have seen modifications of the case with modern sealrings on 101s which have a similar situation on the magneto drive.
    Felt-or corkwashers between magneto and the case were also used back then. I have seen different setups of these.
    Be careful to correctly adjust the play of the mag gear with thin metal-plates below the magneto.
    gsottl
