primary drive oil
  • ticulbart21
    • Mar 2012
    • 3
    primary drive oil
    hi!what kind of oil for the primary drive is recommended for a big chief 1928 74ci??
    and for transmission??
  • Tom Lovejoy
    • Aug 2006
    • 951
    Surprised no responces, I would say 50 wt well work fine for both. Thats what I am using in my 25 Scouts, good luck with your Chief.
    • gharper
      • Nov 2009
      • 528
      I'm running a Greer clutch in my 24 Chief w/ sidecar and I use 20-50 oil, as reccomended with the new clutch. If you're running the old plates, use a 30 Wt oil as they tend to drag and hang up. If you're going to ride much, I would suggest a Greer or King Clutch, light years ahead of the original and it saves your gears too!
      Gene Harper
      • redfred84
        • May 2003
        • 399
        I fully agree with Gene's response, however, I use NON-Detergent 30wt if the original clutch is still in use. I really like the modern Greer clutch. They can handle straight 50wt, and it doesn't have to be Non-Detergent with the modern material.
        RF.
