mocking up 48 chief
  • bigmikecar
    • Dec 2011
    • 34
    mocking up 48 chief
    hi all after installing fender molding trim is it wise to trim down mounting bolts ?they seem like they stick out pretty far into the inside of the fender? i can see after painting fenders and sheet metal final assembly is going to be a bear not to butcher new paint thanks m.c.
  • tomfiii
    • Jun 2007
    • 314
    It would be good to do this ,because you won't like it if the fender is slightly off and they drag against tire especially the front and dragging when installing front tire.
    • starklite
      • May 2010
      • 62
      Yes - cut the studs so they are even with the nuts.
      Gary
      • indianut
        • Feb 2005
        • 308
        That right there is why you want to get those fenders, chainguard, etc. to where you can install and remove them smoothly and effeciently, with NO stress points to prevent future cracking, BEFORE you even buy your paint!
        http://laughingindian.com/
        A.M.C.A. Member Since 1986
        • rigb
          • Jun 2009
          • 143
          I agree, after mock-up and paint, a little lock-tight and a dremel works for me, then a quick shot or dab of paint to seal them. Just my input.
          • bigmikecar
            • Dec 2011
            • 34
            hi again okay frame powder coated forks rebuilt and mounted handlebars new and mounted tires and rims new brakes gone thru and mounted. fenders and accessories lights trim ,sheet metal mocked up and ready to dis-assemble. kick stands mounted. what should be my next step? should i re-wire now run hareness and switch or wait till the motor installed ? what can i get done while i wait on motor and painted parts to come back ? m.c.
