Early sportster top triple clamp
  • spudzylla
    • Jan 2011
    • 28
    Howdy, I have a question to ask of the experts!. Was the top triple clamp for K-models and early sportsters steel? I found a steel one at the local shop, but it is slightly different than the aluminum ones found in later years. It doesn't have a casting number that I could see, and the cutout for the cables to go through is different also. I don't have a picture of it or an original one. I am working on a 57' xl and would like to have a proper one. Any help would be appreciated....thanks Mike
    • 4775
    Mike,
    The top clamp is indeed steel on the early Sportsters. The one you need has ears on it to mount the ignition and light switches, two on each side facing forward. Without those it won't work for your '57.
    Robbie
    • spudzylla
      • Jan 2011
      • 28
      Thanks for the info. I 've got a good how it would look, but does anyone have a picture of one?...again many thanks...Mike
      • jmanjeff
        • Apr 2008
        • 252
        Here is a pic of the the on my bike , you will need to go HERE It is to big to post
        Jeff Bowles
        Arkansas
        Membership # 14023
        1957 Sportster
        • JohnR
          • Feb 2004
          • 211
          Is one switch for ignition the other for lights?
            • 5948
            yes it is.
            • spudzylla
              • Jan 2011
              • 28
              Thanks for everyones help. I went back and he had 3 of them. The first one that he showed the first time had all mounts ground off. Thats why it looked a little strange to me. When I went back and inquired further, he pulled out 2 more. One had a set of headlight bracket mounts similar to an aluminum clamp, and the other had all 4 extensions including the 2 half-moon switch brackets and the stamped steel handle bar cover that has sportster embossed on it. I picked that one up. Thanks again. These forums are great!.
