Race bike question
  • olddaze
    • Sep 2008
    • 65
    Race bike question
    On the K model race bikes there is usually the corner cut off of the cam cover and the kick cover. Was this done solely to save weight? or was there more to it than that, because if it was it seems like alot more could have been cut.
    Member# 7397
  • Sargehere
    Member since 1972
    • Jul 2006
    • 971
    To replace the drive chain in nothing flat. No parts needed to be removed if you threw the chain. Just reach in there and guide the new chain around the sprocket. Otherwise, you're taking off the clutch throwout, exh. pipe, kicker.
    Gerry Lyons #607
    http://www.37ul.com/
    • olddaze
      • Sep 2008
      • 65
      Smart fellers. Thanks
      Member# 7397
      • dlm32
        • Jul 2009
        • 110
        If you decide to modify a stock cover, remember it takes a fair amount of force for the worm gear in the side cover to push the clutch push rod and separate the clutch plates. That cover only has a couple bolts securing it to the engine case ands it needs a fair amount of flat surface contact between the cover and the engine case to spread the load out. Also, many of those stock (non modified) covers cracked or broke out right in normal use. Modifying the cover may increase you chances. I have two unmodified covers and both were fixed in the past.
        David Morrill
        Sylacauga, AL. USA.
        AMCA #15284
        Deadly Dave's Blog
        Sharing the Lost Stories of Early American Motorcycling.
        http://dlmracing.blogspot.com/
        1921 Harley-Davidson Model J Racer
        It will break a hundred, if you drop it from a plane!
          • 5947
          I know an old time racer who used to remove the dowel pins between the cover and case. He also made new bolts out of aluminum. His theroy was that if the chain came loose it would hit the cover, the bolts would break and no parts would get damaged.
            • 6003
            Did he ever win a race?
            • MJW
              • Mar 2007
              • 127
              I know from experience how catastrophic a broken drive chain can be if it stacks up on the drive sprocket, first bike, doing a doghnut, dad was impressed...Mike
                • 5947
                Many........
