More on K Model Oil Lines
  • jtp1955kh
    • Sep 2009
    • 15
    The CAD oil lines for my 55KH were readily available from Sporty Specialties in Fullerton, Ca. They are the same items from the V-Twin catalog PN 63507-52 and 63570-52A. They also have the correct lines for 56 and above. The part that does not show anywhere is the Oil Feed Line Hose PN 63517-54. I suspect this is because it is rubber hose. Based on 5/8 clamps, I suspect that is the OD of the hose and standard rubber hose can be cut to the needed length. Can anyone confirm the proper inside diameter of the hose used?
  • bmh
    • Feb 2007
    • 901
    My 52-57 book lists oil suction line ; flexible, 63517-52 for 52-early 54 and 63517-54 for later 54-57. It does not show any clamps at all but rather compression type fittings with 63529-52 sleeves and 63527-52 nuts. There is an Elbow at the case 63539-52 for 52-early 54 and 63539-54 for later 54-57 (45 degree) and fitting 63533-52 at the other end for all. Don't think clamps were used at all until after 65, seem to remember a photo in an old sportster service manual that clearly showed rubber lines attached with a double wrap of safety wire instead of the familiar band clamp.
    Brian Howard AMCA#5866
