info for 1965 xlch sportster
  • aka HAWG
    • Jan 2007
    • 487
    can someone help
    I have a 1965 xlch sportster and I believe the bottom end is full of oil and need to drain it, I cannot see a drain plug anywhere - am I missing it in my looking.
    if no plug how do you drain oil from the bottom end - motor is still in frame
    I removed the timing hole screw - when I kick the motor over it shoots oil across the garage.
    I just purchased the bike - it has sat for over 5 years and never kicked over during that time
    aka HAWG
    1914 EXCELSIOR BELT DRIVE SINGLE
    1914 excelsior belt drive single carcuss
    1940 indian chief military
    1965 sportster xlch
    1969 sportster xlch bobber
    1971 bsa A65 chopper
    1969 harley ss350 sprint
    1960 harley topper
    1963 harley topper
    H model whizzer on cheiftain bicycle
    H model whizzer on schwinn bicycle
    1949 harley model 125 bobber project
    1959 harley model 165
    1960 harley super 10
    1974 indian 70cc dirt bike
    EXCELSIOR - ALWAYS MAKES GOOD
    • 5950
    Strange thing about drain plugs. Some have them and others don't. They are located under the primary cover on the side, not the bottom.
    • koanes
      • Apr 2003
      • 656
      If there isn't a drain plug for the crankcase located below the flywheels near the case mating surface, you can either use a syphon gun or the old fashion method with lung power. You need a small diameter tube such as aquarium air line. Stick it down thru the timing plug hole. You might want to warm things up a bit to get the oil to flow easily.
      Kyle Oanes AMCA # 3046
      • aka HAWG
        • Jan 2007
        • 487
        thanks for the input
        heating up the oil would help but this is some of the problem, with the bottom end full of oil it is very hard to kick it over, and the oil shooting across the garage with timing hole cover off do not want to run it - if I can get it started
        aka HAWG
        1965 sportster xlch
        1960 harley topper
        1963 harley topper
        • koanes
          • Apr 2003
          • 656
          I wasn't very clear, I meant to say warm the oil in the crankcase with a heat source like a heat gun or hair drier so it would be easier to syphon.
          • joestuff
            • Mar 2007
            • 49
            Take off the plug or oil light sensor off the front of the oil pump, and the fitting that holds those on. Then pull out the ball and spring, and it should drain from there. Might take a while.
            • Thumper
              • Feb 2009
              • 13
              All Ironhead Sportster cases have at least one(centered in middle of trans housing) gearcase drain. Unless it has been welded up, alot of them were welded up in the old days because at the time the heli-coil was not such a plentifull item. As the years progressed they added the one on left case under primary. I believe 72 (I'll have to check) they added the one under the flywheel ass. (in the case) so that what little oil was held could be drained w/oil change was done(also helped to scavange pieces of a broken ring-piston in case of topend failure). Pulling the sending unit off the front of oil pump, along w/check ball & spring will not do you any good. It will not effect gearcase oil, it will however drain your oil tank.
              Gary
              THUMPERS Inc.
              THUMPERS Inc.
              Classic Harley Davidson Motorcycles
              Speed-Custom-Resto
              386-960-5736
              • aka HAWG
                • Jan 2007
                • 487
                time to ask another question
                I want to take the magneto out of the bike and use points - what timer do I need to look for
                I know I have to change other things to make work but having trouble with mag and like the points set-up better - also want the headlight on due to provincial law and safety
                any help accepted
                aka HAWG
                1965 sportster xlch
                1960 harley topper
                1963 harley topper
                • koanes
                  • Apr 2003
                  • 656
                  The hard thing about this conversion is finding a place to put the battery. I have a 65 XL timer I would sell if you are interested. Since you are removing the mag from the CH I guess you're not too worried about originality. The 65 timer is a 1 yr only, the 66-70 is a little different.
                  • aka HAWG
                    • Jan 2007
                    • 487
                    I will send you a pm thanks
                    aka HAWG
                    1965 sportster xlch
                    1960 harley topper
                    1963 harley topper
                      • 5950
                      Originally posted by aka HAWG View Post
                      can someone help
                      aka HAWG
                      If you start the bike the engine will purge the excess oil by itself. Be sure you have a pan under it.
                      • aka HAWG
                        • Jan 2007
                        • 487
                        thumper - it is not the gearcase I had questioned it was the crankcase
                        manuel ( chris ) that would be a great idea to try but when was the last time you tried to kick over a motor that was filled with 5+ year old SAE 50 oil - and a magneto ignition. this is the reason I needed to drain the crankcase, so I could get it to kick over easier
                        I removed the ball and spring - kicked a few times and let sit for about an hour and repeated till no more oil driped from the engine
                        aka HAWG
                        1965 sportster xlch
                        1960 harley topper
                        1963 harley topper
                          • 5950
                          aka HAWG
                          I quit kickin' as soon as I bought one of these.
                          Roller-start system for motorcycle racing professionals, extreme motorcycle riders, and vintage motorcycle collectors.
                          • Thumper
                            • Feb 2009
                            • 13
                            Mag to Dist swap.......
                            Would have to go w/the 66-74 (or so) oil bag & battery box. Go w/CycleElectrics gen if not wanting the extra wiring(& reg) to contend with. If needing any parts(including dist) contact me have everything you need to do the swap-over.
                            Gary
                            THUMPERS Inc.
                            Speed-Custom-Resto
                            386-960-5736
                            • Coolbreeze
                              Long Rider
                              • Aug 2007
                              • 320
                              Draining oil / replacing oil tank
                              Trading the "CH" oil tank for one with a cavity for the battery should not be hard. There are dozens of people like me who would gladly trade a battery tank for the CH version.
                              About your problem with draining oil: All I have to do with my '60 CH is let it sit for a few weeks, and "presto" a good amount of expensive H-D oil has found its way out of the engine onto the floor!
                              George Tinkham
                              Springfield, IL
                              www.virmc.com
                              AMCA # 1494
                              1941 Indian 841
                              1948 Indian Chief
                              1956 H-D KHK
                              1960 CH
                              1964 BMW R69S
                              1984 Moto Guzzi V65Sp
