I did an oil change two weekends ago about  a half hour prior to leaving for the Jersey Shore. (I live up here in North Jersey)
For some reason????...I decided to go with a multi-weight oil (Castrol 20-50 Multi-Weight) the 4T Motorcycle specific. I normally use their 50 straight weight, but could not find any locally at the time. Hence the purchase of the 20-50wt at the Pep Boys store....(Although they did have Straight weight 50 motorcycle oils in Valvoline, Lucas and Purple in various Dino and Synthetic types, I went with the Castrol multi....again I don't know why.
First thing I notice after kicking it over was a lower cold oil pressure reading. No problem...It showed good pressure, just not as high as the straight wt when cold starting.
We took off on the bike (riding two up that day with the wife) the next thing I noticed about 20 minutes into the ride was a definite quieting down of the top end valve chatter. Temprature outside was a balmy 80 something. I thought, hey this is great. Oil pressure looked about the same...you know just above '0' on the oil pressure gauge...got one of those auto type oil pressure gauges which refuses to show small increments of pressure...basically serves as a fancy idiot light.
Anyway...got to our destination....about 2.5 hours of straight riding, checked oil level...looks good, little lower down from the top notch of the dip stick, no problem, this bike always uses a little oil thru various leaks...Harley you know.
Next check back home after about a 6-1/2 hours of almost constant riding for a total of about 9+ hours of riding time. Again a little lower, no problem.
Went for a short trip of about 75 miles last weekend, parked the bike and forgot about it. Go to start up the bike yesterday afternoon, checked the oil level and whoa!!! ...the oil level is down to just below the lower notch of the dip stick....???
That's at least a good Quart+1/2. I started the bike to see if maybe the oil had weeped past the check valve and was laying in the sump...Let the bike run approximately 5 minutes, re-checked and nope, levels the same. I will take the bike out for a short ride today and see if there is any significant return of oil to the tank.
If not, my conclusions??...The 20-50 wt definitely helped quiet down the top end.....but oil consumption was up significantly over the 50 wt straight oil of the same manufacturer and/or the 20-50 multi wt oil tends to leak past the check valve...which the straight 50wt never did.
Anyone use multi-wt in their Ironheads with similiar results??
I was thinking of going with a multi-wt synthetic oil next chainge like Lucas or Mobil/Castrol, but now i'm not so sure.
  Hrdly
  Hrdly
