Identify P cams
  • rick anderson
    Identify P cams
    I have a set of P cams I'm selling on ebay and I was asked if they were for 900 or 1000.
    Can some one tell me the difference and how to identify these cams?
  • motorhead1
    57-70 engines used a vertical timer. 71 and later timed from the #2 cam. If the #2 is larger on the cover side and has a small threaded hole in the end, then it is for 71 and later. Other than that, lift and duration are the same for 900 and 1000.
    • rick anderson
      Thank you motorhead1.
      Rick.
