K Model Frame
  • 59xlh
    • Apr 2018
    • 24
    K Model Frame
    Curious how to identify a light weight K model frame. Thanks in advance, Tom.
    • 4775
    Hollow footrest mounts, no sleeves on front downtubes are a couple of hints.
    • 59xlh
      • Apr 2018
      • 24
      I just have a frame. Has hollow footrest mounts. Left side mount was moved over to the right side. No brackets for oil tank or coil cover. Anything else? Thank you.
      • chuckthebeatertruck
        • Jun 2018
        • 684
        Do you have a K model frame or do you have a KR/XLR frame?
        There's two "light weight" frames. The street version and the -R racing version.
        The street model K frames are not considerably different from other K frames except for the hollow rests and tubing. However, AFAIK all of these lighter frames for street bikes were made in 1952 and 1953 -- featuring the "old" steering head angle of 28 degrees. Starting in 1954, all K model and then the succeeding XL models used a 30 degree neck. So, a quick test for street frames is the neck angle.
        KR/XLR is a different beast -- and they were also "light weight" -- there were many variations of the frame and I'm not well versed on them.
        And, yes, that 2 degree rake change makes a really big difference in how the bikes handle. I run an early K frame with an XLH motor in it -- it handles much better than any other K or sporty I've ridden or owned. But, it is not the slow rolling turn in that you get with the later bikes -- it turns in the second you push on the bars or switch your foot position :-)
        • 59xlh
          • Apr 2018
          • 24
          There is no kickstand mount and no sign of it being removed. Frame is dated 3D. I put a magnetic protractor on the neck and appears to be 28 degrees.
            • Jun 2018
            • 684
            That’s sounding more and more like a possible race frame.
            I'm not well versed enough to comment further.
