I purchased a 1970 CH as a burn-up in 1973. Over the years (around 1980 or so) I stroked the motor and added an electric start. The use of the larger, electric start battery assembly necessitated cutting the welded the upper oil tank bracket from the frame and I've since lost the bracket (of course!). Now that I'm restoring the bike to original, I'm removing stroker stuff and the electric start and must re-mount the CH oil tank. Therefore, I need to know what the welded top bracket looks like so I can fabricate and reinstall a replacement. Can any one help with some photos, measurements, etc.?
Thanks so much,
Bill Pedalino
Thanks so much,
Bill Pedalino
