K Head Apppication
  • slamiste
    • Mar 2010
    • 260
    K Head Apppication
    I have a set of K heads with part numbers 16684-52 and 16682-52 stamped on the underside. Both are also stamped with a "1" under the part number. What K model application would these be correct for? Does the "1" designate a certain compression ratio?
    Steve Slaminko
  • wz507
    • Oct 2016
    • 8
    These heads are for early K models with low lift cams. With very minor modifications they can be fit to any K or KH engine.
    • slamiste
      • Mar 2010
      • 260
      Thanks for the info!
      Steve Slaminko
