67 CH clutch hub bearing
  • hdhikaru
    • Feb 2010
    • 217
    Hi I am trying to replace the clutch hub bearing and spacer as its loose.
    so.. how do you remove the bearing? looks not retainer so..... just press on back? tks Shin 2021-12-14 16.25.jpeg
  • chuckthebeatertruck
    • Jun 2018
    • 680
    The bearing is retained by the ratchet plate. It is a serious job to replace it.
    unless your wobble exceeds .006 run out, it's generally a good idea to leave it be. They all are loose and wobble to,some extent.
    be sure to repair/replace the missing rivet in your ratchet plate.
    • hdhikaru
      • Feb 2010
      • 217
      OK, thanks!! Happy new year
